It is currently Thu Aug 21, 2025 3:53 pm
 Post subject: Air Brush reccomendation
PostPosted: Fri Sep 06, 2013 8:58 am
City: Quakertown
State: Pa
I need to get an airbrush for some touch up work. I figured that I could use it to spray a burst as well. Is there a particular Brand/Model that is reccomended??
Scott
PostPosted: Fri Sep 06, 2013 9:47 am
First name: duh
Last Name: Padma
Paasche H, ~ with all three tip sizes...although you will probably only be using the #5
http://www.paascheairbrush.com/products/airbrushes-airbrush-parts-and-accessories/Airbrushes/single-action/h-1
and this is a must...a moisture trap, with
a 15 ft hose
Get a few larger bottles as well.
US made, this gun has been the work horse for industrial, commercial and fine artists for over a century.
Single action..idiot proof.
Highly recommend staying away from the double action modes for this type of work.
Blessings
PostPosted: Fri Sep 06, 2013 10:30 am
First name: Danny
Last Name: Vincent
Good advice from Padma. I bought one on his recommendation a number of years ago. Thanks my friend. I bought this set http://www.airbrushoutlet.com/hset.html. I also picked up some larger pots and lids. It works great for spraying alcohol bursts. Not so much for lacquer bursts. I did one and wasn't happy with the results. I use my gun dialled down a bit and it does a much better job. The spray gun was easier to feather in and make a more uniform pattern.
PostPosted: Fri Sep 06, 2013 10:40 am
I got this one: http://www.woodcraft.com/Product/208401 ... h-Kit.aspx
I hooked it up to my air compressor at 40 PSI and it atomizes super fine. The external mix makes it super easy to clean up.
I got a larger jar to hold more finish.
Old growth, shmold growth!
PostPosted: Fri Sep 06, 2013 11:39 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Paache H or the VL if you want more paint control. Iwata makes a good one too.
Jason Moe
LaCrosse WI 54601
PostPosted: Fri Sep 06, 2013 11:59 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use a badger 200. It is a single action and works very well. I find that I can get most accessories and parts at my local hobby shop for badger airbrushes. No one around her carries the Paache stuff.
Brian
PostPosted: Fri Sep 06, 2013 2:39 pm
First name: duh
Last Name: Padma
HOBBY LOBBY
2215 Lebanon Valley Mall, Lebanon, PA, 17042
(717) 274-2806
PostPosted: Sat Sep 07, 2013 7:07 am
Last Name: Howard
City: Magnolia
State: Delaware
the Padma wrote:
HOBBY LOBBY
(717) 274-2806
Yes but Hidden Hanger is only 3 miles away rather than 16 and they carry badger. And it is right beside home depot and other stores I frequent. Thanks for the thought.
Brian
PostPosted: Sat Sep 07, 2013 6:54 pm
Last Name: Russell
State: Michigan USA
Ah,,, A topic I know a lot about. In my previous life I painted cars and am also an artist so I did a lot of custom painting (in the 60's and 70's). I have owned all the brand name airbrushes but found Paache to be the most consistent. I own both the single and dual action but the dual action is my go-to brush.
However I would highly recommend buying the DeVilbiss EGA Touch up gun over an airbrush for guitar work. You can get it with a fine needle and cap which will get down to the detail level of an airbrush with the largest cap and needle. An airbrush is designed for drawing and painting small details so the biggest fan pattern you can get is still pretty small. They also do not hold much material so you they will not cover that much of an area.
I use my Touch up gun to spray the finish on my guitars as well as for detail work like shading wood tones out and doing bursts. The best part of using a touch up gun over an airbrush is it doesn't get clogged nearly as much as an airbrush. Also airbrushes are designed to spray very thin material where my touch up gun has no problem spraying un-thinned lacquer.
Here is the one I use:
http://www.devilbiss.com/Products/SprayGuns/TouchUpGuns/AirSpray.aspx
Here is a Gibson I just refinished using it.
PostPosted: Sun Sep 08, 2013 7:27 am
Last Name: Howard
City: Magnolia
State: Delaware
Yes, I agree with Robert. My Devilbiss SRI pro gun which is designed for small spot repair and color blending has replaced my airbrush in most applications. I only use the airbrush for very small spot repair these days.
Brian
PostPosted: Tue Sep 10, 2013 12:25 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I used to have a Paschee VL, and thought I could do bursts with it... it turned out to be useless because even the largest needle is too fine for guitar work, not to mention it doesn't hold much material. I now use a spray gun for sunburst... it has a 1.3mm tip so it will do both clear and burst fairly well. However now I fell in love with FP so the gun and compressor just sits there gathering dust...
Typhoon Guitars
